Gt Coupes w/KONI Yellows
I JUST got my Koni's, Vogtland 'Leveling' Springs, Steeda Upper Strut Mounts, Pan Hard Bar & Brace and Lower Control Arm Relocation Brackets installed on Friday and would like to know what setting people out there have the shocks and struts adjusted to? How many turns, etc. etc. Thanks!
RE: Gt Coupes w/KONI Yellows
I have my KONI's turned all the way to the firmest position and haven't tried anything else yet. It turns much more precisely and rides awesome on smooth pavement but with the many bumps in the road I bounce around a lot in my seat (bouncy bouncy, haha). I'll have to try softer settings, but I love how responsive the car is. I am already used to the lower ride. I'm glad I didn't go any lower than the Vogtland .8/1.2 drop. I can still go over speed bumps up to around 20 MPH. I also love how the car stance is balanced.
ORIGINAL: 2006gtmike
Even though I've done more than 10 track days in the first year that I owned my '07, I still like driving with the stereo on and the a/c cranking in Houston summers. The stock GT Mustang has a pretty amazing ride/handling compromise IMO.
How's the ride with the Vogtland Leveling Springs? Did you get them from Sam Strano? I understand you can adjust the Koni's from smooth to firm. Have you tried adjusting them yet?
My biggest question is - can you really adjust the ride with the Koni's, in other words can you make it smooth for daily driving and then firm it up when you want to?
-Wayne
ORIGINAL: Sleeper_08
SlideWRX
Aren't we all ready for spring!
I was wondering what tires you were running in the winter as mine will also be a DD in winter.
SlideWRX
I think pretty much any snow/winter tire would work well. The narrower the better, although the load rating of the tire may be an issue if you go too narrow. I'm running 225's on the stock 8 inch rim, and run them at 35-37ish psi because of the slightly lower than stock load rating.
Tom
SlideWRX
What you have done is consistent with my plans for next winter except that I was going to get a second set of 18 x 9.5 rims as the stock rims won't clear the planned GT500 brake kit.
