HELP: REAR SHOCKS WON'T COME OUT!
I am replacing OEM rear shocks with Tokico d-specs.
I am removing the OEM shocks. I have unbolted the lower shock bolt. I opened the trunk hatch pulled the cover back and hand ratcheted the upper shock nut but it will not loosen. As I torque the upper nut, the whole assembly rotates so the nut is not looesening but just twisting.
I rebolted the bottom of the shocks to see if that would work butit didn't.
See nut location number 1 on page 1 of this.
I do not have air tools, just hand tools. I don't think the torque of a hand ratchet is doing the trick. Do I need to somehow find a power tool that can apply repeated and high speed torque to the upper nut assembly.
HELP!
HELP!
RE: HELP: REAR SHOCKS WON'T COME OUT!
The very top of the shock bolt should be like 8 or 10 mm (I think, it might be even smaller). If you hold the top of the bolt with the 8 or 10 mm wrench youcan loosen the mounting bolt from the rubber mounts. You do not need another person, just 2 hands.
The less risky methods . . .
Sometimes you can get a small wrench on the shock stud above the nut to hold it still and use a box or open end wrench to turn the nut.
A cordless impact tool might work if there's room to get it in there. (This is a tremendously useful tool to have, with a spare battery pack, BTW)
A nut-buster can be used to split the nut.
You can also put a deepwell socket over the nut and stud and work it back and forth with an extension until the shaft breaks. I am assuming that the old shock is trash.
Norm
Norm
ORIGINAL: Norm Peterson
Norm
Norm
I ended up having to take an adjustable open ended wrench to clamp on the top of the rod while I used a fixed 18mm wrench to torque the nut loose. Finally worked.
Thanks.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
