Steeda Heavy Duty Front Upper Strut Mounts
I have the Steeda Heavy Duty Front Upper Strut Mounts (555-8120) and was wondering if it is possible to take advantage of the adjustability when at the track.
They are presently set to 3/4 degree negative camber as the car is a daily driver.
Is it possible at the track to loosen the bolts off and then move them to increase the negative camber to whatever the maximiume is it will give. Then once the track day is overmove them back to 3/4 degree negative. If it is possible how doI know both sides move to the same camber angle.
RE: Steeda Heavy Duty Front Upper Strut Mounts
They have pointer indicators at the open hole in the front of the strut tower, if your car is already at 3/4 negative ....you can take a sharpie and make a dot on the strut tower ...then have it aligned for - 1.5 or what ever the max is then mark it again with your sharpie , so you will have points to choose from when ever your at the track or daily driver .
ORIGINAL: Sleeper_08
Basically I'm asking the for procedure for adjustment.
ORIGINAL: Vapour Trails
I currently have these coming in the mail. Are adjustments made by loosening the 4 strut mount nuts under the hood or by the strut to spindle bolts?
Is it possible at the track to loosen the bolts off and then move them to increase the negative camber to whatever the maximiume is it will give. Then once the track day is over move them back to 3/4 degree negative. If it is possible how do I know both sides move to the same camber angle.
ORIGINAL: sd07gt
To move them after loosening the 4 bolts under the hood do I have to have the weight off the front wheels?
I can only get about 1 degreeof negative camber with my Steeda HD strut mounts and Eibach prokit. I might install camber bolts also to get more negative camber. They move a lot easier with the car jacked, but you can still adjust them with weight on wheels.
09-10-2015 08:39 PM
09-08-2015 11:50 AM
