Quantum Brak Ducts Installed
#31
RE: Quantum Brak Ducts Installed
ORIGINAL: Argonaut
I run the D-Specs 2 Front, 4 Rear. Falken RT-615s:40 front,38 rear Hot. I also have -2 degree camber in the front which really makes it stick. I developed this setup on AX courses but it seems to work really well on the track also. Of course I have a lot less power than you but my rear is really plantedand Ill only push the font end if I make some bonehead move.
My next set of tires will be Nitto NT-01s. From what I hear they like lower pressures, probably have to experiment a little with them.
ORIGINAL: Sleeper_08
Argonaut
I was wondering what you had your D specs and tire pressures set to on the track. I'm running 2 front and 2.5 rear and 40 psi hot all round.
Argonaut
#32
Rotors from newtakeoff.com are a steal. $40 for a pair of fronts or rears (have to email or call for the rears, since they aren't on the website). So far, my fronts last about a season and a half and the rears last twice as long. THIS is why I have no desire to go to a big brake kit. $40 for a pair of rotors!!
#33
ORIGINAL: Import_Slaya
#34
^ new take-off would refer to rotors removed to upgrade/replace them. They would probably be very low 'dealership' mileage and maybe not used at all.
I would not hesitate to purchase them under those conditions.
Jazzer
Jazzer
#35
ORIGINAL: Argonaut
Thanks - that is a steal. Are they slightly used - what does it mean'new takeoff'. I know where Ill be ordering from next. How does the stealershipsleep at night charging 70/rotor - they are crooks!
I just put another set of fronts on this weekendabsolutely no wear on them at all.
Galactic
04-29-2019 02:56 PM
09-10-2015 08:39 PM
