brake upgrade
RE: brake upgrade
Ok, I'll take the advice. I'll keep my stock rotors and upgrade to braided lines, fluid, pads, and ducts. that'll save me $650 off my budget. Can't wait to get em in and get back on the track.
RE: brake upgrade
ORIGINAL: blksunshine
RE: brake upgrade
RE: brake upgrade
ORIGINAL: RodeoFlyer
It's been said over and over again - ducts, good fluid, braided lines, and good pads will do the job just fine. BBK's might give you longer pad life but more tire budget, so you still lose in the end. Slotted rotors are a waste. They don't help much at all. You might get a little less pad transfer and in the rain some water dispersion, but at $200+ a set when stock takeoffs are $39 it's a waste.
I took Rodeo's advice as well a few years ago as I started down the tracking road, and have heard it echoed again and again by the old salts at the track. Unless you have money to burn (and many at track events do), the above brake mods are all you need. Then put your money into track time. That is going to save seconds per lap. Many of the other mods just save tenths after your driver mod is ironed out.
09-25-2015 06:42 PM
mungodrums
Suspension
09-24-2015 10:12 PM
mungodrums
Suspension
09-07-2015 07:22 PM
