how do suspension mods really help your ride out?
ok, so i know that i want to add suspension mods to my pony but i just have one question. how do suspension mods really help us out?
i mean they sell control arms and stuff, but how could they really be that much different that the factory? they have the same geometry and travel distance and such right?
or am i just being a total newb and don't really know what the hell im talking about?
most are made of higher quality materials, are more rigid, last much longer, and have much better bushings.
You will notice most of your suspension mods in the form of a rougher ride, ie. LCA's, springs.
I also have the tokico d-specs which can be adjusted to make your ride very stiff or to make you feel like you are floating.
The aftermarket suspension parts may make the ride more rigid "or rough" but you definately feel like you have more control over your car and feel planted to the ground
Last edited by mac10chap; 08-12-2008 at 02:59 PM. Reason: didnt finish what i wanted to say
The other suspension mods are less dramatic and may or may not be needed depending on your goals and the amount of drop due to a spring change. If you are into drag or street racing and you experience wheel hop...then a set of control arms and possibly relocation brackets will do you nicely. If you are into serious cornering then camber plates or bolts, good PHB and UCA are on the menu. It really depends very much on how you want to change the behavior of the car.
From a near-duplicate thread in the 4.0L Handling section https://mustangforums.com/forum/s197-handling-section/473188-how-do-suspension-mods-really-help-your-ride-out.html
and
ORIGINAL: vancebreck
Here is the answer you don't want....it depends.
It depends on which parts you are replacing and what for. New springs can lower the center of gravity for the car. Even 1 inch can be significant considering the weight of the car. But you also have to consider speed. The different will obviously not be felt at lower speeds so the faster the speed the more significant the difference. New shocks and struts can make a ride smoother or more firm. A firm stance will allow you to "feel" the road more and react faster when on a road course. Other parts, like anti-roll bars and lower control arms are made of better materials which again do not dampen the feel of the road allowing for better or quicker control. Will new suspension parts make a significant difference on a daily driver? Depends on how you drive and how you like the feel of your car.
ORIGINAL: Norm Peterson
Generally, aftermarket control arms come fitted with firmer bushings, which provide more accurate location of the wheels/axle and a more precise "feel". Understand that rear axle end motion is not purely up-and-down vertical. It also includes little fore/aft movements and some slight axle steering in most situations, and greater bushing compliance (think "squishi-ness") usually increases these effects. In a drag race launch, firmer bushings tend to suppress wheel hop. Up front, firmer bushings also translate into better camber control and better front grip (read: slightly higher cornering limits and a little less understeer when you're hustling it a bit through the turns).
Norm
Norm
Here is a good thread that explains LCAs and UCAs http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
09-08-2015 11:50 AM
