Lower Control Arm Choice?
#21
#27
Not to bash BMR at all they are good parts but i have seen the comparison of UMI to BMR and the LCA bushings are like almost twice as big on the UMI. Give sam strano a call a stranoparts he'll hook you up,
That being said BMR is widely used and highly spoke by for most. Just wanted to give you another option for the same if not less money.
As for the CHE or any other non greaseable it just seems to be wrong as its a friction piont and should require some kind of lube to make it work smoothly.
Just my 2cents
Just my 2cents
#28
did not see the poly/poly ended adjustable LCA on stranoparts website, but they are showing as available on the UMI site. Those are nicely built units (all the pieces have easy "on car" adjustments with a center position nut) and are significantly cheaper than some of the other name brands. Thanks for the info!
When I get ready for the suspension purchases, I will definitely hit up Sam.
#29
