Lets talk about Watts-link suspensions
Joolander - I have a new respect for you. I am one of few people in here that know what your avatar is.
Have - Maximum Mototsports panhard bar. Cheap and effective.
Want - Griggs
Pros - does it just a little better than a panhard rod. adjustable roll center.
Cons - COSTS A LOT OF MONEY BETTER SPENT ELSEWHERE ON THE CAR FOR STREET/AUTOCROSS/OT guys.
Want - Griggs
according to sam strano the most racing proven mustang handling person, watts links do nothing for the mustang's handeling on the track because of the way the panhard bad is designed it changes the roll center on a track very little. However on the street a watts link significantly improves handeling because when the roll center changes the tires shift around loosing grip in the process and messing up the handeling too.
The problem is that watts links add lots of unsprung weight, unless they are of the diff cover variety. Furthermore continuing his words not mine, watts links are hugely overpriced.
He'd only put them on if you have:
Front sway bar
damper
springs
lower control arms
and only if you're driving on the street, because on the track a car with a watts link preforms the same as a car with an aftermarket pan hard bar and you would have just wasted money.
The watts link also lets you run a stronger rear sway bar without sacrificing ride comfort, which which can increase handeling a very significant 10%!
Front sway bar
damper
springs
lower control arms
Here are some other threads that discuss the Watt's link;
https://mustangforums.com/forum/s197...nsive-way.html
https://mustangforums.com/forum/s197...atts-link.html
Here is the Wikipedia article with a neat animated graphic showing how it works -
http://en.wikipedia.org/wiki/Watt%27s_linkage
IMHO the Watts link is over advertised/overrated in terms of cost/benefit. From what I've found, an adjustable panhard bar with poly bushings is way more than most people need and costs less. This the route I chose for a daily driver and occasional open track toy.
Its funny - the Watts link is one of those subjects, much like coil over dampers, that seems to stoke passionate responses, both pro and con, from all sorts of people, most of who have never driven on one and are only regurgitating what they have read elsewhere or trying to rationalize why they didn't purchanse one.
Two people whose opinion I respect much - F1Fan and Sam Strano (in spite of the post regarding Sam's comments above) have both driven Watts Links and think they are worth it. In fact, if you go back over time reading F1Fan's posts you can see how he evloved from a Watts link hater to a Watts link lover once he tried it and then installed it in his car.
Unless you actually have high performance driving experience in a car with one installed, I just don't see how you can answer this question. My 2 cents.
.... Two people whose opinion I respect much - F1Fan and Sam Strano (in spite of the post regarding Sam's comments above) have both driven Watts Links and think they are worth it. In fact, if you go back over time reading F1Fan's posts you can see how he evloved from a Watts link hater to a Watts link lover once he tried it and then installed it in his car.
Edit to add: I took Legion's advice and Googled Sam Strano and watts link and found some posts.
