I have $300, need help w/ suspension....
So...I'm thinking BMR stuff because it's affortable and I've heard good things, but what do I need? I have a 2006 GT auto w/ non-intercooled Vortech supercharger and 3.73 gears. I'm having trouble getting traction when launching. So what would help most besides tires? lower control arms? upper control arms? ext...
LCAs for traction and no wheel hop. I use the CHE fixed lengths and am very happy with them.
For launching at the track, you'll want drag slicks or drag radials for tires for traction. You can put some on stock rims to save some bucks.
Thanks for the replys so far, so if LCA's are for traction and wheel hop then what do UCA's do? Should I get both LCA's and UCA's?
You will have to pick either LCA or UCA for $300. There isn't a LCA and UCA combo pack out there that will help worth less than $300.
I purchased Spohn chrome moly rod/poly adjustable LCA and most of my wheel hop disappeared. But wheel hop is not strictly due to one particular suspension component. Shocks, springs, tires, diameter of the tire, LCA, UCA all play a role in controlling wheel hop. I can say that on this forum, there is also no consensus as to which single component affects wheel hop the most. Some say shocks, others LCA.
Hello, thank you for considering BMR. I would suggest a set of our non adjustable lca's with a set of relocation brackets. The lca's will help with traction and make the car more consistant. The relocation brackets will allow you to adjust the instant center of your car and will help with weight transfer. They will also eliminate any wheel hop that you might have. Give me a call i can give you our pricing.
. . . wheel hop is not strictly due to one particular suspension component. Shocks, springs, tires, diameter of the tire, LCA, UCA all play a role in controlling wheel hop. I can say that on this forum, there is also no consensus as to which single component affects wheel hop the most. Some say shocks, others LCA.
With respect to LCAs vs shocks, I think it depends on the wheel hop cause (there can be more than one). If it's related to the OE bushings' compressing and springing back under load, the control arms are what need attention. If it's due to extreme and rapidly occurring rear end squat, relo brackets would be first choice for a lowered car and especially for drag racing, with shocks probably being the better (only?) choice for a daily-driver that is not going to ever get lowered.
Personally, I generally suspect the LCAs in these cases, since the OE shocks are pretty stiff in 'bump'. If you're getting wheel hop on wet pavement, it's probably not due to rear squat issues, which leaves the control arm bushings.
Norm
