Tokico D-Spec Adjustment Questions
D-specs were one of my favorite mods! I also do not have the extensions and can change all 4 dampers in less than 5 minutes. You should buy the shocks/struts first without the extensions and then buy the extensions later if you decide you need them, which you probably wont. Its amazing how the feel of the car can change by just a simple damping change.
First, H&R Race springs are quite stiff. While I feel Koni's are better in general, the difference is even greater with your springs. I've run both dampers, and even dynoed both to see how they compared. Suffice to say the Koni's have a lot more room on top than the D-specs do, and with the H&R's higher rates that's damping you might well need.
As for the remote adjusters. Save your money. It takes all of another 2 second to access the top of the shock (D-spec or Koni) directly.
Thanks for the info everyone!
I read another topic that was a D-Spec vs Koni that was started by you. You and F1 Fan went back and forth, and the info that I got from there was great. After reading that thread, I am leaning pretty hard toward the Koni shocks/struts, and after reading your post in this thread I will be getting the Konis. Either way, it seems that I will be quite happy!
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-16-2015 07:53 PM
Daddys Girls GTs
09-14-2015 08:46 PM
