HELP Tokico install questions !
#41
OK the D-Spec are now in, but have a question.
I find that the adjustemnt is very loose, I explain. When I adjust the front ones. I tight them (clockwise) until it stops and then go counter clockwise 4 turns, but when I do this the screw has no resistance it feels very loose, there's no resistance,
Is this normal ?
Is this normal ?
#43
Yes. I believe the spring in the valve needs movement to “set”. When I go back to my street setting after a day at the track, the number of turns to all the way closed is what I had previously set.
Shifty Magoo
08-25-2015 03:08 PM
