Yet another wheel and tire question.
Upon my return from deployment, I plan on getting the Steeda Ultra-light silver 18x9.5 and 18x10. I am up in the air about tire choices. I am thinking either Nitto NT555 275/40/18 for the fronts, but the wheels I am stuck between 295/45/18 or 285/40/18 for the rears. I am not worried about my speedodometer being off, I have tuner and my car is not lowered and I don't plan on lowering it. I am leaning towards the 295/45/18 for the rear.
Personally, if you are staying with the 18's, I like the 255/45/18 tires on 9" rims up front and the 285/40/18 on 10" rims in the rear. For your info, the 295/45/18 size is about 1.2 inches larger in diameter then stock and you will loose some of your gearing, while with the 285/40/18 your gearing will stay relatively the same. And gman, don't be so dead against lowering because if you go with either of these set-ups you will certainly notice alot more space now in your rear wheelwell. And, this will drive you nuts (IMO). Hope this helps......!!!
Hey gman......
As long as the tire rotates at the same rate as your stock tire (meaning it's the same height)- it doesn't matter how wide you go. Therefore, it will not affect your speedometer, odometer, ABS or traction control.
The 295/45/18 will be taller, so they wont have the same rotation as the stock tires, but I'll just adjust the revs with my tuner.
295/45 is a bit on the tall side, but at least you're working with 4.10's for the straight line stuff. Understand that with 295/45's on the rear and 255/45 or 275/40 up front that you'll be giving away about 0.4°, maybe 0.5° of caster, and your headlight/fog light aim will be a bit low. You might or might not notice these effects.
Norm
There are a number of small consequences, some of which add a litle understeer and some of which reduce it at a different portion of the corner. Hard to say whether any individual taken at random would find that better overall or worse, if they'd even notice it in the first place. I'd say that if you don't notice how a car's handling changes slightly as a set of tires goes from new to worn-out/used-up, you probably won't notice (and aren't cornering hard enough for it to matter anyway). No flame intended.
Norm
Norm
I would go with 275 front and 295 rear more tire both in front or in rear improves grip, while less tire reduces it.
Raising the rear benefits the mustang in terms of handling usually.
Staggering tires does not improve your performance, people are often confused by this.
Staggering tires is intended for a few reasons:
To reduce weight in drag racing
To be used on 60/40 weight distribution cars to keep the same amount of rubber per pound of chassis weight and make balance front to rear therefore significantly better.
To help in the rain because a smaller front tire will break up the water better and prevent hydroplaning.
If you're already running the biggest tire possible in front.
You don't fall under any of these a 255 front tire will reduce your performance.
09-16-2015 07:53 PM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
