Shocks/struts to match Bullitt springs?
I'm starting to plan out my suspension mods and I'm trying to decided on shocks, struts and springs. I don't like the "slammed" look and after daily driving a Corvette for a year I'm tired of scraping the bottom of the car.
Anyway, what I would appreciate is a stiffer spring. I have my eye on the Bullitt springs which I can get cheaply. They lower the car about 0.25 inch front and rear and are stiffer than stock.
However, I have no idea how much stiffer! Does anyone know the spring rates?
I'm also thinking about the non-adjustable Konis instead of the shocks and struts that come with the Bullitt.
How well would these components match up?
What I'm especially looking for are Bullitt owners out there that have replaced their shocks and struts, but not the springs and their impressions.
I can tell you that the Bullitt springs (i) will not lower the car to the degree you would notice it and (ii) aren't appreciably stiffer than the standard GT springs.
When I decided to make my Bullitt handle, I replaced the springs.
In your case, I bet the non-adjustable Konis would help alot by themselves.
Forget the Bullitt springs and any of the Bullitt suspension, it's terrible.
I'll probably just wait and use whatever springs Ford installed on the 2010 track pack. I'll be able to get the takeoff parts for next to nothing, I know they won't lower the vehicle much if at all, and they should be a good match for the Koni shocks and struts. If the gains are small, then it won't matter, since the price will likely be cheap.
If I decide I can't wait, then I'll just keep the stock springs and install the Koni parts. Better handling, stock ride height, and it won't ride like a truck.
The least aggressive I've seen are the H&R OE Sport Springs. They lower the vehicle .75 inches front and .75 rear.
I did some searching and it's not hard to clone the 2010 suspension, nor the performance. I've done most of the mods already, except with what I think are better parts (more aggressive gearing/tune, stiffer lower control arms, light wheels, etc.)...
My car already runs a 13.5 in the 1/4 (60 foot time was only 2.18 seconds), that's O/D on, traction control on, with stock 235/55R17 tires and me not launching it at all. I can't wait to take it back and try the car out with the wider tires/lighter wheels and nitrous.
Here's what's on the 2010 track pack:
-Dual-piston front calipers with performance brake Pads
-Performance 3.73 axle ratio
-Recalibrated Electronic Stability Control® (ESC) – requires manual transmission
-GT500 front and rear stabilizer bars
-Front strut and rear shock tuning
-Rear GT500 lower control arm
-19" premium painted wheels
-Summer-only performance tires (255 series)
-Tire mobility kit (available Summer 2009)
No mention of springs, apparently, it just uses the stock springs. Konis and a set of Steeda front/rear sway bars and endlinks and I'll be there.
According to the info Ford has released the Bullitt uses the same spring rates front and rear as the standard 2005-2009 GT. It was supposed to use the AC rear springs from the base V-6 Coupe which have a 6mm shorter free length than the BC springs that come on a base GT Deluxe. The only unique suspension parts I can find on the Bullitt are the shocks.
