Tires wearing in center - Pilot sport A/S
if the center is wearing faster than the outside and inside of the tire then you're over inflated, assuming the outside and inside are around the same tread depth. if the outside, center, and inside are all at different tread depths then it's a combination of camber and tire pressure causing that.
Overinflation causes the tread to contact the pavement
in a way that eats the outer edges when aggressivly turning.
So its overinflation for both your tire wear problems.
Are the outer edges feathering at all like they would with
properly inflated overaggressive turning applications?
I have these tires, but only have had them on for the past 1500 miles.. So im no help, mine look brand new and are not even wearing yet =).. They better hold up for spending $502 for TWO rear tires..
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
M3hunter
09-05-2015 03:42 PM
