Toyo Proxes R-888 Tires
Colin - I have a lot of time on both the NT01 and the Nitto 555R2. I'll 2nd Rodeo's opinion the the NT01, they are a super DE tire. The 555R2 is also very good. They have a more street oriented tread pattern with the same 100 treadwear ratting. Very durable and predictable. A little louder than a normal street tire on the highway but not bad. I'm happy using either one. Both of these are better track tires than the KDWs.
The NT01 come in a 275/40/18 which is 26.65 which is pretty close to my present 27 but I'm not sure they would be a good idea as a "summer" tire.
If they would just make the NT555R11 in 285/40/18 then that would be my choice for next year!
Thanks for the suggestion but I'm not sure there would be much difference between my KDW2s and the NT-05, as both are street tires, to have a noticable effect in my lap times.
My R1Rs are 26" in dia., and I'm lowered about the same as you (rocker panel to ground is around 5" at front and rear). Around town I haven't had any serious problems with them. I do have to give new found respect to parking curbs, as I seemed to hit more than usual when I first got them. Also, I can no longer make it up my Rhino ramps w/o a boost (but I have a Classic chin spoiler; I don't think this would be a problem on an undressed bumper).
5th gear at RA this year was pretty much useless. So if I wanted a max top-speed effort, I had to stretch 4th on the front straight (nothing too terrible, just held it a bit more than I would have if I had a usable gear to go to).
Best,
-j
Best,
-j
It's more of an SCCA Solo "Street Touring" category of street tire, so think midway between a top-shelf but true street tire and R-comps. 7.2/32" tread depth and "200 treadwear" vs 10/32" and 300 for the KDW2's. A 200-treadwear ST tire will out-grip a 200-treadwear pure street tire (but won't outlast it).
I think the NT-05 has been discussed in the Street Touring forum at SCCAForums.com.
Norm
Since Norm brought it up, the treadwear on the R1Rs is 140 (the lowest I've found in an officially advertised "street" tire) and has 8/32" tread depth.
I got them as my "summer" street tire, but I'm tracking them for this year as the dedicated set of wheels/tires won't come until next year. Fortunately, I no longer drive on the street enough to worry much about how long they'd last under daily duty.
Best,
-j
Best,
-j
Best,
-j
Best,
-j
My avatar is an old photo and I am now also running the CDC Classic front spoiler. Your comments about running 26" tires on the street are appreciated.
I've already asked my Dad to make me a short ramp from a 2 x 10 to be able to get a kacjk under the back so I know what you mean.
This leaves the top speed in 4th as my only concern because I am already running at full revs (6,250) at the end of the Mosport straight, 133.0 to 133.5 mph. We can see from the data that shifting to 5th is the pits - again confirming what you saw. With the smaller diameter stickier tires we would be on the limiter faster and longer. H'mm there is always the option of a six speed conversion
They may be both street tires, but the NT-05 is a bit further up the food chain.
Norm
Norm
What is needed is to win the lottery so that I can then go and buy a GT2!
I'd say just go for the NT-01's and be done with it.
When i had my Griggs setup fox mustang years ago i drove around on the street with 275/40/17 Yokohama A008-R's and it was a grip monster. I did not drive it often though, and i dont think i would do it if i drove it daily.
When the tires wear out, just get new ones!
