g trac brace or a arm support bar
Old 08-18-2009, 03:25 PM
mykim72
mykim72's Avatar
Default g trac brace or a arm support bar
worth while mod? can you feel a difference?
mykim72 is offline
Old 08-18-2009, 04:01 PM
157dB
Cut & Paste Expert
157dB's Avatar
I home made mine and its a s stiff as a you know what of a preacher...
And yes those are 1/4" thick mounting plates with 1/4" thick back-up
plates to sandwich the frames sheetmetal for stouter attachment points.
And an extra piece of DOM tubing...
Notice how the brackets are not straight with the tubing as the
stangs attachment points are not square/parallel. I tacked the ends
into place on the stang then removed the piece for final welding and
painting...
The OEM bar is made from swingset quality tubing with flattened
ends to attach it. And costs an arm and a leg at the stealership.
My 07 S197 didnt come with one as most pre 08 models didnt have
them cept the verts. Now they all come with the A-Arm bar...
Attached Thumbnails g trac brace or a arm support bar-brace2small.jpg   g trac brace or a arm support bar-bracesmall.jpg   g trac brace or a arm support bar-bracesmall2.jpg   g trac brace or a arm support bar-bracesmall3.jpg
157dB is offline
Old 08-18-2009, 05:36 PM
Philostang
Philostang's Avatar
I have one with torque limiters to the tranny. I can feel the limiters, as shifting feel and precision is enhanced, but I can't say I feel anything from the brace itself (acting on the K-member). But then again, they're cheap and easy to install, and as I recall even Ford went to adding them on the GT500.
Best,
-j
Philostang is offline
Old 08-18-2009, 09:41 PM
Sleeper_08
Sleeper_08's Avatar
Best,
-j
and on convertibles and GTs starting somewhere around 08
Sleeper_08 is offline
Old 08-19-2009, 10:58 AM
mykim72
mykim72's Avatar
better question...who of the AX guys runs this?
mykim72 is offline
Old 08-19-2009, 11:15 AM
KeneticEnergy
KeneticEnergy's Avatar
i threw on the steeda g trac. made the steering feel more precise. youre not gonna get the holy **** my front end is ridiculously tighter feeling. just more precise steering and a little more chassis firmness.
for 50 bucks, yeah id do it again if i went back in time
KeneticEnergy is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
winner99
10-01-2015 10:52 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: g trac brace or a arm support bar
