Questions about brake upgrades
So my big question about brakes is that I am looking at upgrading mine, but I don't want to exceed what is really necessary. I was thinking about just getting drilled/slotted rotors, would that be a significant improvement over the factory system, or do I really need to get a new set up with larger rotors and calipers.
Stay away from drilled and slotted rotors - they're hype. Stick with Brembo stock replacement pieces.
Buy these -
Motul 600 or ATE Super Blue fluid
Hawk HPS or EBC Yellowstuff pads
braided lines
Happy Motoring.
Buy these -
braided lines
Happy Motoring.
Another mod that really helps is front brake cooling. Several kits are available including Quantum and Agent 47. I'm running the Quantum kit on the track and am happy with it.
After switching to the EBC Yellowstuff pads this year I found they don't hold up well to serious track use. My rears were down to the metal after 4 track days. I'm now running Hawk HP+ front and rear on both street and track and they seem to be holding up better on the track but do squeal on the street.
If you do decide to upgrade then IMHO a cost effective upgrade is the GT500 kit
http://www.fordracingparts.com/parts...tKeyField=9540
but you have to find wheels that also fit a GT500. The kit includes the stainless steel lines which alone are worth about $200. Pads are readily available from several companies because the same calipers are used in other cars. Replacement rotors are also pretty inexpensive. The rotors are pretty heavy but that means they also absorb a lot of heat.
It really isn't that bad, I get gas for 3.07 a gal, so the price isn't as bad on my wallet as my foot is, gas mileage at 145 mph sucks! I already have 18 inch wheels, I just don't want to buy something twice. I want to get what is good the first time, but not necessarly the most expensive. So just get the kit for the front? Cause I think it would look really gay having cool looking brakes up front, and factory in the rear.
I agree that having the stock rotors and calipers on the back with 18 inch wheels looks a little funny but for me appearance is secondary to peformance. Heck my car even has a cloth interior and to get that I had to order it and wait 6 weeks.
If you want bling then there are lots of BBKs for the front and rear that come with slots and holes. Just remember that drilled rotors will crack under heavy use and when you replace them they cost more money.
I just got some front Centric Premium rotors and Hawk HSP brake pads, after researching quite a bit settled on this set-up, alot better than stock (I had already warped front stock rotors, LOL) and a great upgrade for just $300 installed.
The "big brake" kits are outrageously priced and won't work with stock 17" wheels !!!!
