want to lower my car soon help me
You dont have to, but they'll wear out prematurely. At least on a 1.5" drop they will. You can always replace them later, but you'll have to do all that work of taking everything apart all over again. Thats what I'm doing. Couldnt afford shocks when I lowered so I'm doing it later. Next summer probably. Its not really a big deal, just know that you will have to do this sooner or later.
Since we are touching on shocks/struts in regards to lowering at 1.5", is it necessary to purchase an adjustable panhard bar and camber bolts if you are installing a set of springs (Eibach Pro's) and shocks (Tokico D-specs)??
Adding to that, would it still be worth eventually going to adjustable UCA and LCA's as well?
You'll need camber bolts (thats what I used) or plates for your alignment for sure. I didnt personally need a panhard bar. Some say they needed it. Depends on your car and your personal definition of "needs" I suppose.
Can you describe what it is about the stock handling that you aren't happy with? What happens, when does it happen, what doesn't it want to do kind of stuff. Include a description of how you're trying to make the car do whatever it is that you want it to be doing.
Listen to F1Fan, or give Sam Strano a call.
i dont want ot have to get supporting mods at first. if i lower the car 1.5 inches or 2 inches will i need something else to support that? what a good height. its my dd but also a track car.
Because it is not clear what you mean by "track car", is that open-tracking on a road course or drag racing (this matters, a lot).
Just my first impression, but when the appearance consideration is listed before performance (and that the appearance concern is described in greater detail), I suspect that the car really isn't being driven hard enough for it to matter a whole lot. Not intended as flame, so feel free to correct me if I'm a bit off the mark here.
Norm
As for struts and shocks I'm going to use the KONI's for my next set.I'm using Steeda non-adjustables and they ride like crap.They are supposed to be designed for the Steeda Sports I lowered my 07'GT with.
Do you want a car that behaves more like a road-race car or a car that only looks like one?
1.5" is already too low for best handling unless you're going to throw a LOT more at the car than just springs/struts/shocks and maybe an adjustable PHB. Words like welding, revised geometry, and "not DIY" come to mind.
Norm
Norm
ok. im not into big flashy rims on a muscle car. im runnning 16'' v6 black rims because they are light and they are fine. i have alllot of power mods like nitrous ex.. but have no suspension mods.
My deffenition of track car, is mostly 1/4 mile, but id like to do some back road racing for fun. but dont base my lowering off of this.
i want the car to look better not having such a wheel gap. and overall i think the handleing isnt too godd compared to my bmw 330. id like to just overall improve the handling. but number one if getting the wheel gap to be smaller and not look so goofy. i can see inside the rea wheel wells allot. but like i said i want the hadleing to be better, and i dont mind if its a tighter firmer ride quality, it not a luxery car.
tell me what i should buy, min. cost cause im doing another build right now
BMW is a tough comparison, particularly since I've never driven one. What are the differences when you drive them over the same road at the same speed?
Norm
this questions for my v6. i am running 245/60/16s so it better than 215 lol
and you are correct, the car doesnt FEEL good handleing. its not to bad just take a turn sometimes the rear jumps and such if i hit a slight elevatedd part in the road, and it just seems a little jumpy and sloppy back and forth.
gt take off sways would help this allot??
i think ill get gt front and rear sway, and maybe a 1'' drop?
the bmw just seems to plant better and doesnt roll and shift around a turn
The PHB can cause a little bit of lateral wandering if the rear suspension is rising/dropping a lot as you drive and you're sensitive to such things. But it doesn't sound like you want to spring for a Watts link, and an inch to an inch and a half of lowering will mostly level the PHB out for a car with only the driver or driver + front seat passenger on board anyway.
Norm
