Suspension Upgrade/ Bolt on's to Improve over stock
Old 12-21-2009, 11:59 AM
Sam Strano
Former Sponsor
Sam Strano's Avatar
If you don't have wheelhop, and most lowered cars don't.. then LCA's are not necessary. What's more is that the hop went away when you lowered it. Putting LCA brackets on, and leveling the arms such as they were stock can well cause it to return.
If you want to upgrade handling you want to look at things like the dampers (shocks and struts), swaybars, PHB or better a Watts link, STB, adjustable endlinks, that sort of stuff. LCA's are not really a help in comparison.
Sam Strano is offline
Old 12-21-2009, 02:18 PM
mcstang
mcstang's Avatar
Default lca etc...
Thanks Sam,
I just left you a message on your voice mail about some things. Thanks
mcstang is offline
Old 12-25-2009, 03:13 PM
StickShifty
StickShifty's Avatar
steedas stop the hop kit is great if you dont want it lowered. if you do, then your going to have to add alot more parts. the stock handling is really bad, compare to a nice sport setup.
StickShifty is offline
Old 12-28-2009, 06:03 PM
BadSteed
BadSteed's Avatar
Ok Im new here to the mustang forum, But why wouldnt you not want to go to a harder bushing than rubber? Rubber flexes , Sure it gives you a smooth ride but lacks in performance If you can get something with little or no play it will be far better. I do know ot will transfer more noise, But the trade off exceeds the problem. Bushings are cheap just takes time to install.
BadSteed is offline
Old 12-28-2009, 11:08 PM
Sam Strano
Former Sponsor
Sam Strano's Avatar
Because there is no free ride in the world. Urethane bushings are cheap, and flex less... but then they also cause bind in certain locations (like the LCA's) which hurts ride and axle articulation. Urethane also cold-flows and as much as folks think they do, they do not last forever. You can run rod-ends, but they can be noisy.
And a problem is only one if the owner feels it is. I mean, if someone is happy with stock power (for instance), the doesn't need a blower even though you might think it's a must have. Parts are like pills. I say that a lot, because it's what I think. You shouldn't take antibiotics for a sprained ankle, right?
Old 12-29-2009, 12:59 AM
DRock
DRock's Avatar
so your saying that the Steeda Comps dont lower the front a the 1 inch that they say they do?
DRock is offline
Old 12-29-2009, 03:03 AM
Sam Strano
Former Sponsor
Sam Strano's Avatar
They barely dropped the nose of my '07 GT by 1/4"..... The rear was about 1".
Old 12-29-2009, 03:38 AM
DRock
DRock's Avatar
So what spring would you pick that is linear and has that kind of spring rate but actually drops the car by an inch up front?
DRock is offline
Old 12-29-2009, 08:25 AM
2010V6Stang
BEWARE! Possible Scammer
2010V6Stang's Avatar
Steeda Sports
2010V6Stang is offline
Old 12-30-2009, 07:06 PM
svtsupremecy
svtsupremecy's Avatar
I got rid of my wheel hop by getting new tires. the stock pirellis wheel hopped real bad , but the nitto 555s really reduced the wheel hop alot.
svtsupremecy is offline
Quick Reply: Suspension Upgrade/ Bolt on's to Improve over stock
