Need info on suspension mods
I have a stock 2010 Mustang GT Premium, glass roof, 19" paint alum wheels, and everything but nav system
I am going to add a bren speed CAI/Tune system, a new exhaust (prob Rouch), and a suspension mod if I find I like them
Can I have some info on suspension mods? Which ones are best to get for handling etc.
I don't want anything super expensive, but it doesn't have to be a cheapy either
Wouldn't it be easier for you guys to just give me advice rather than tell me to look somewhere else? Linking me would be more helpful than just saying search. I'm new here and don't know much about the site
All I have done so far is change out the rear lower control arms for some J&M control arms, they helped a little for wheel hop. This spring I will be installing the upper control arm from UMI. Hope this eliminates the wheel hop all together.
Part of the reason for asking you to search a bit is so that you can refine where it is that you want to take this. I certainly can't put your number on what' "too low", just as one example. I might consider anything more than 1" too low, while other's won't look at anything that doesn't drop the car at least 1.5". Some like a more level car stance using rear springs that lower more than the fronts do, others prefer the rake. If nothing else, you at least get an idea what things are by consensus either generally good or not very good for handling. Somewhere, there's a thread that tabulates some of the available spring data (yes, it exists, no I don't have a link for it, and if I have a copy of the data itself it isn't on this computer).
As has been asked already, just what do you want the car to do differently as far as its handling is concerned? Is there anything in its behavior that you DON'T like? Things that you think it should do better, more of, or less of? What's your tolerance for a stiffer ride quality?
If it wasn't for your mention of ride height, I'd just suggest Koni non-adjustable shocks/struts, maybe Sam Strano's adjustable sta-bars, and leave the springs alone at least for now.
Handling is more than just cornering g's; it's a lot about how the car "feels" to any given driver when driven at least reasonably hard. Skidpad lateral g's only gives a rough idea of performance POTENTIAL.
Oh yeah, 10 - 3 Colts.
Norm
Here is a link to the spring thread Norm mentioned
https://mustangforums.com/forum/s197...g-allowed.html
LCA relocation, lowering springs, new dampers, swaybars, etc.
I personally am starting with steeda sports springs, koni str.t dampers, and a umi 1055 adjustable panhard bar, after that I am getting the Strano stage 3 swaybar kit.
