Nitto NT01 Hot Pressure Suggestions?
I was told by a guy in our group with 10 plus years experience that ideally, you want the wear pattern on the tires to touch the tip triangle molded into the side of the tires. I've attached a picture from the inside of my tires that shows the triangle. I was playing with the pressure and got a bit too low and wore half of the triangle off on the outside.
I'm running the 245 width tires and start around 35 cold and they get to around 41 hot. 41 pounds gets me right to the tip of the triangle less than 40 and I'm rolling past the center of the triangle. But again, I'm on narrower tires.
I'd shoot for 38 pounds like Argo and Rodeo say and check the wear pattern then adjust accordingly.
Cheers,
Cheers,
Cheers,
Cheers,
Keep in mind that targeting the triangles involves more than just tire pressure. Camber (and even toe and caster to some degree) will also play into the wear pattern. More negative camber will shift the wear pattern away from the tire outside edge, but you may in fact be quicker. Or not, as every car is different and every driver is different.
I'm not at that point either but hoping that maybe by later in the season I'll be needing a good tire pyrometer!
that's the best way, take tire temps on the outside, center, and inside and use those numbers to set the pressures. from what I've read you really need a nice contact style pyrometer rather than a infrared one like the stores usually have. something like this...
http://www.summitracing.com/parts/RE...8730/?rtype=10
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
