Let's Talk LCA's...
BMR "Combo" LCA's. Polyurathane bushing on the body side and a spherical end on the axle side. One of the best things i have done to my car. They eliminated all my wheelhop. They are made extremely nice and i would buy them pver and over agian without hesitation. They do not make as much noise as a full spherical settup would but there is a slight amount more noise transmitted, but with you exauset i doubt you would notice anyways.
If you have any more questions shoot me a pm.
The biggest reason to get adjustable LCAs is if you need to correct the thrust angle. IOW, get the axle perfectly square in the car. You can use them to tweak pinion angle, but at some risk of "un-squaring" the axle.
Reasons you might need to do this include (a) the axle is a little 'off' from square as it sits, and (more likely), (b) you add relocating brackets but either don't get them installed identically side to side or they aren't quite identical to begin with. Keep in mind that everything fabricated has a 'tolerance', and that sometimes out of tolerance happens.
Billet is far more for show than performance. If you're going to give it severe abuse - drag racing and hard launches are still the big ones here even if you do manage to stay out of wheelhop - choose some other design. Don't consider tubular aluminum unless you're going to inspect it from time to time (unlike steel, aluminum has no stress level below which it will last indefinitely).
Norm
Norm
breaking
10-02-2015 01:27 PM
