KONI Yellow Shock Issue
My driver's side rear shock looks to be leaking as there is a dark oil residue all over it.
Does anyone know if the their "lifetime warranty" covers this failure?
Should I just call Koni directly or what exactly is the replacement/warranty process?
The other rear shock looks allright, but should I replace BOTH rear shocks?
They haven't even hit 15,000 total miles on them!
I had to warranty a STR-T strut from Koni about 8 months ago. It was a semi PITA but, in the end they honored the warranty. Actually, the process goes something like this. You go to the Koni NA web site and download a Warranty Claim form, fill it out and fax it along with a copy of your invoice from when you purchased the unit. Koni will provide you with an RMA number and offer to send you a replacement unit, with a core charge, then you send the broken/defective unit to them for evaluation and if they deem the cause to be material or workmanship related they will refund your core charge.
