Roush lowering springs
Just purchased a set of 4 lowering springs from Roush- -part # 402331. They advertise lowering the rear 1.25" and the front 1.00"
My question is.. do I have to have the car realighned after the install?
Thanks,
Lee 2007 Mustang GT convertible
Thanks,
You don't have to but it's probably a good idea after tearing down your front end to install springs. Have you installed them yet? If your front end isn't nibbling or pulling you're probably ok. Your biggest worry should be camber out of range but at that lowering amount you're probably still in spec.
I would stay its damned near mandatory to get the wheels realigned. My friend lowered his 05 some years back and despite my prodding, he didn't get it aligned. The car tracked straight and didn't seem to have any problems. Coming back from an assignment a couple years later, he blew a front tire on the highway. Inside of the tire was worn down so much that it blew, while the outside of the tire looked completely fine. Albeit, he did have Eibach Sportlines, which are more of a radical drop, and perhaps this is more of a story of the importance of monitoring your tire wear, but you get the idea.
Its not essential that you do it right away. I would recommend you wait a week or so for the springs to settle before getting the alignment.
take it from an 10 customizer of all types of cars. Get your front end aligned anytime you touch your suspension or get new tires. Its just not worth the cost of the new tires.. once your tires start wearing incorrectly the tires will pull you alignment off even after you try and get them aligned.
