D-specs and H&R springs are awesome!
Just installed me d-specs with H&R race springs and the car is awesome! Handle like it is on rails. Found the setup for $450 slightly used which is a steal for all of it. Installed it all in almost 5 hours total and this was the first time I had ever done suspension work. These forums help out alot, thanks to you guys for posting the "How To's" or i would have taken it to a shop and wasted even more money.
Cleanest 1986 SVO in Orlando
Funny you mentioned that the rear is stiffer than the fronts, because I've noticed that as well. Driving over bumps at slower speeds, I notice that the front goes over fairly smooth, but the rear is pretty jarring. Maybe "jarring" is too strong of a word, but you get the point. Maybe I'll try a softer setting on the rear. Can't hurt on the street, if anything it'll just promote more initial understeer which is fine for the street.
Not a bad idea to switch over because the shaker is also a flat black and it looks pretty good. The ride is alittle soft in the front but i cant tell what the shocks and struts are set at because I dont have the key to adjust it. Waiting for Tokico to send me a key so i can play with the adjustments still
They are perfect. Like on rails and i love them. Thinking I may need CC plates because you can see the camber in the fronts. Also im getting a steering wheel shimmy and im not postive but i think an alignment is needed
mungodrums
09-28-2015 10:54 PM
09-27-2015 03:16 PM
mungodrums
Suspension
09-24-2015 10:12 PM
