Strain Gauges On STB?
I was thinking about the debate over whether or not the front STB brace is worth it and then was wondering if anyone has actually instrumented one?
It has been a long time since I played with strain gauges at university but could they be used to determine once and for all if the STB actually does anything other than look good and add weight in a bad place?
It could always be set up with a linear potentiometer that ran between the strut towers. It would measure deflection in both directions (compression and “stretch”). And it would also measure “twist”. But it wouldn’t be easy to verify how much is stretch, how much is twist.
Would a strain gauge work in compression? That is what you would be looking for between the strut towers wouldn’t it?
Shouldn't be a problem. It's not like the S197's have underhood temps near "Lava" or anything.
I work in a company building specialized foundations and we usually use it here for estimating drilled piles performance. I could 'sneak out' with it for a weekend.
Anyway I'm no engineer, so I'll stand aside and listen to the experts. I have championed the notion of no STB performance gain from my limited research before and been shot down. Maybe I'll get some ammunition this time or be proven wrong. Again.
Cheers.
