Stupid question... maybe not.
Old 11-20-2010, 07:25 PM
D'prived
D'prived's Avatar
Default Stupid question... maybe not.
You've just installed new front springs and struts and you put the top plate on. Everything is looking good and you install the strut/assembly with the four studs back in your car. My question... the center nut that holds the top plate to the strut... how the hell are you supposed to torque that nut down when the center part also spins with it?
D'prived is offline
Old 11-20-2010, 07:32 PM
JDWalton
JDWalton's Avatar
IIRC, when you had it out of the car, dont you hold the center with a wrench and tighten the nut so the top plate is locked into the nut?
JDWalton is offline
Old 11-20-2010, 07:33 PM
D'prived
D'prived's Avatar
I thougt I did. My drivers side torqued okay but the passenger side just kept spinning and spinning.
D'prived is offline
Old 11-20-2010, 07:48 PM
JDWalton
JDWalton's Avatar
well thats what I'm saying, I do not think you tighten the top when your putting it in the car.
JDWalton is offline
Old 11-20-2010, 07:52 PM
JDWalton
JDWalton's Avatar
http://iihs.net/fsm/?dir=60&viewfile...g Assembly.pdf
JDWalton is offline
Old 11-20-2010, 09:45 PM
D'prived
D'prived's Avatar
What you posted doesn't make any sense. It says "to install tighten to 46 lb-ft." Okay... and how to I do that with a box wrench?
I did exactly what's in the picture and then after I installed the strut assembly I tried to torque it with a torque wrench and nothing happened.... on the passenger side. Driver's side was fine. At what point is the inside "locked down."
D'prived is offline
Old 11-20-2010, 09:58 PM
JDWalton
JDWalton's Avatar
sounds like you didnt have it tight enought before you put it back in the car.
JDWalton is offline
Old 11-20-2010, 10:02 PM
D'prived
D'prived's Avatar
That's what I'm thinking but I had my son stand on the spring while I tightened down as much as I could with the two wrenches. I mean you can only go so far with a little 8mm wrench.
D'prived is offline
Old 11-20-2010, 11:16 PM
6-Speed
6-Speed's Avatar
If the strut stem has a hex nut, then use a 6pt socket to hold it in place and tighten the retaining nut with a 13/16" box end wrench. I attached a 13/16" crows-foot to my torque wrench, positioned the opening 90 degrees relative to the handle and torqued to 46 lb-ft. This gets the torque close to 46 lb-ft ... perhaps a little higher.
If you really want to be precise on the torque, see post #2 in this thread:
http://www.svtperformance.com/forums...g-springs.html
6-Speed is offline
Old 11-21-2010, 08:03 AM
D'prived
D'prived's Avatar
Thanks much 6-Speed! That's exactly what I was looking for. Where did you get the open end wrench attachment for the torque wrench?
D'prived is offline
Quick Reply: Stupid question... maybe not.
