Upgrading via Sam Strano or full Griggs GR40 SS?
I am taking delivery of a 2011 GT500 SVTPP on Friday, and while I know SVT did a good job on the SVTPP, I want the ultimate in cornering, while at the same time having a smoother than stock ride and the ***-end planted and composed on un-even pavement with the suspension loaded up (like on a on/off ramp sweeper) oh, and I want the rear-end to hookup with the power that Ford gave it. Wasted power in burnt rubber is just such a waste and disappointing, I want 0-60 times like the GT350 is getting.
I know this isn't a GT500 specific section, but I figured I would reach a broader audience here.
The Griggs set-up claim to fame is the torque arm, which according to articles I have read is the biggest factor in being able to put the power down and do away with the rear sway bar (unless needed for fine tuning), both in a straight line and accelerating out of the apex in a turn.
It seems that the two things that Griggs does compared to others is the Torque Arm and relocating the rear shocks to a true coil-over design. Other then that, everything else that Griggs does can be done with bolt-ons (LCA, coil-over shocks, bushings all around, and camber/caster plates)
Sam, I would love to hear from you on this.
Also, anybody else please chime in.
Of course you are going to get a biased answer.
If you take a look on my website you can see some in-car video of a Mustang, and that video shows g-data. You can see quite high numbers, also watch me drive the car, and see that it's far from a mess. The numbers are gotten on Hoosiers, but Griggs also uses Hoosiers. But in all the video of Mustangs currently on the site, I'm doing it on stock sized wheels, and with much less invested into the suspension.
I'd never add a Torque Arm, regardless of brand. It's heavy, and what's worse it adds a lot of unpsrung weight too. And fwiw, a TA is not somehow a replacement for a rear swaybar. I've very familiar with torque arms, and quite frankly if I could swap my Camaro over to a 3 link easily, I would. It's more compact and the upper arm does the same job, keep the axle from rotating around.
I don't particularly see the need to reinvent the wheel here...
Struts aren't so bad either... they seem to work pretty well on M3's and Porsche's. And the front end on this car is very BMW-esque if you take a close look at it.
True, some struts are good, but coil-overs are always better.
I had KWV2 on my 335i and they were a lot better then the stock struts on my M3.
I am not looking for pretty good. I am looking for, knock your socks off, kick-*** handling
Sam,
I'm just gathering info. I only want to do this once. It's the only mod I plan on doing to thR car.
I just want something spectacular, worldclass, and professional, that will keep up with Porsches and the like.
Sam,
I don't want you to take offense and I'm not asking you to justify anything,
I am looking for technical information, why one is better then the other and how/why what works to achieve my goal.
I have no experience with Mustangs
