Urgent: Koni STR.T install question
Installing my STR.Ts now...are you guys putting moly grease (or similar) on the bolts that attach them to the frame?
Also, Do the bolts nuts need locktite? Or just a heavy dose of 'torque' (say ~ 120 in/lbs or so?) Thanks dh |
Originally Posted by dan_h
(Post 7603712)
Thanks! I was more concerned with 'squeaks' after install but if you say 'no grease' on the bolts, i'm going with 'no grease'....synthethic, moly or otherwise!
Dan |
If you are reusing the "use one time only" Ford fasteners then blue Loctite is a good idea.
Do not use red Loctite. |
