The rear end doesn't look like it shifted too far from the drop. Did it shift over to the driver's side?
i think so, but it's barely noticeable. in those pics i had the stock panhard bar on. now have maximum motorsports bar.
Originally Posted by pdonket
The rear kind of looks like it's pulling a doggy style lol, although I kind of like a bit of rake personally. The front definitely looks low though, I'd raise it just so I wasn't quite as afraid of tearing the hell out of it when you encounter anything but completely even ground and roads!
Looks great though! How's the ride feel?
Originally Posted by Radiater
How is the ride and handling with this new setup?
it felt really good on the street. definitely not bumpy, even when they were very low. the car was easier to rotate (even more) with these and the ST swaybars. i only had one gripe with the front end and that was the ride height (my fault). it rubbed everywhere. i now run the front an inch higher and it's clears almost everything. then again there isn't much topography here in fresno.
Originally Posted by Import_Slaya
Your car looks great.
But...why is this post in the "handling" section? It really should be in the "appearance" section, and you will probably get a lot more input.
i think coilovers affect handling just as much as they affect appearance.
