Order of modifications?
Looks like I might have to save my pennies. The Koni look like they are about 200/each. I was looking at the blue Tokico on americanmuscles' page but looks like the Koni scores better. I have some Monroe in my Five Hundred sedan but dont think they would find their way into the Mustang
Thank you Norm for your good insight. Are you an engineer by chance?
The amount of shock/strut damping for best grip comes in somewhere around two or three times the amount of damping that provides the best ride. It would be fair to assume that most cars end up with shock damping chosen closer to best ride than best grip, especially for those cars not intended to be the king-of-the-hill cornering/handling champs.
Noticeable wallowing or bouncing suggests damping that's well below the level associated with "best ride". "Best ride" and even "best grip" damping still permits the suspension to overshoot its final position a bit, but most people don't particularly notice this. There's other things going on that shock/strut damping is affecting, and most people don't intentionally drive hard enough anyway.
Most people barely use 1/3 of a car's ultimate performance anywhere except for WOT acceleration and the occasional emergency braking event. If you used just half of the car's cornering potential, you'd drive away from just about everybody every time the road stopped going straight. And that's about the level where additional spring/bar stiffness starts actually benefitting the performance from a mechanical standpoint.
Stiffer springs and sta-bars will also tighten things up, at least in terms of how much roll and pitch (nose dive/rise, tail squat/lift) happens. The biggest benefits in street driving from these are probably subjective. I'm not trying to discount the importance of the subjective side here (this can be very important when operating up near the limits), but the amount of actual performance used on the street - and how much the car moves around on its suspension as a result - really isn't all that much.
There is one other thing about stiffer springs and bars - the extra stiffness requires somewhat more damping in order to stay in the same place on the "wallowing - best ride - best grip - etc." spectrum. Otherwise the extra stiffness has an easier time "overpowering" the shocks/struts (essentially, you'd move downward on that scale). Even if you only upgraded the bars and left the springs as OE, the suspension would still need a little more damping.
You'll find that many of the people whose compromise point is somewhere out on the handling side of ride vs handling prefer Konis, particularly the yellow adjustables (aka Sports). Not because they might impress by seeming a little spendy, but because they work (know that there are shocks out there that make the price of Koni yellows sound absolutely bargain-basement).
Norm
Norm
I've had both Tokico and Koni adjustables and the most noticeable benefit of the Koni's is that they are less 'harsh' as described by Norm.
The instructors that I went to VIR with teach there are 6 ways to steer a car;
1) steering wheel
2) throttle on
3) throttle off
4) brake on
5) brake off
6) choosing the wrong gear
The better the power/torque to weight ratio the more important 2) and 3) become and the more you need to learn that the throttle pedal is a rheostat and not an on/off switch. My car is only an 2008 GT but with the Roush SC still has more power than the 2013 GT's. I'm still learning.
1) steering wheel
2) throttle on
3) throttle off
4) brake on
5) brake off
VVV see sig below.
For LCAs BMR or Steeda but for relocation brackets Steeda all day. There is like 4 different height holes on the Steeda Unit to fine tune anti squat to your preference. Whatever you do for the control arms I would read into the bushing selection as some Poly/Poly units will bind in roll and bind is bad. If you can find one that offers poly on the chassis side and spherical on the axle side. Note of course spherical bushings will transmit extra NVH but the poly bushings should mitigate that.
bradleyb
11-27-2015 07:50 PM
mrappe
09-26-2015 10:16 AM
