Has anyone removed their panhard bar brace?
Well it was pouring rain today, so I didn't want to drive down my crappy dirt road to test it with no brace. Instead I removed it and cut the lip off. I tried bending it first, but it wasn't going to happen without some serious heat. It can't weigh more than 3lbs.
Wish I had taken a before picture.
Yeah I am trying to figure out what part you removed, and judging by the "clean area" I can make a pretty good guess... but that area doesn't even look like it comes near to the exhaust?
If you aren't 100% sure this is the cause, I'd check your muffler hangers... I know the rubber insulator on mine are stretched/worn so every time I hit a bump the metal of the hanger hits the metal of the actual muffler hanger bracket and the sound makes it sound like it's the panhard hitting the exhaust... food for thought?
I'd advise against removing it. I installed UPR's PHB brace on my car. No clearance issues.
http://www.uprproducts.com/mustang-p...-brace-05.html
I removed the lip that hangs down on the forward facing side and ground down both sides. You can see wear the lip starts in this pic, it used to run the full length. I'll know tomorrow if it's still hitting.
Ooops, I have a tendency to over look it. (Your original post said your exhaust hits it... kinda selected past the "and now my phb hits it.) Ah well, I hope it solves your problem. This a temporary fix or you plan on leaving it like this? Doesn't look like a big hit to the rigidity of the piece but who knows...
