Made an A-arm brace
Yeah, since mine is a 2006, I never got one from the factory. About $52 from AM for the Ford part, but I had about $25 in materials and only used half of it. I may find another use for the remainder.
Im not exactly sure, but I think Ford started adding the brace on all models sometime during 07 or 08. I've read that the brace is more beneficial in chassis bracing than the more popular strut tower brace, so I thought why not, can't hurt.
http://www.americanmuscle.com/frpp-lca-brace-0512.html
Making your own parts is a Mustang necessity!
The FRPP unit is actually probably stronger, being steel round-tubing. Where as mine is aluminum square tubing. I just chose that because it was cheaper, lighter, available, and easy to work with.
I'll do a chin-up on it while installed to gaurantee my craftmanship!
Its all well and good unless you look at the attachment points on the stang
and see that they are essentially at an angle and not straight to each other.
You have essentially made an aluminum stress inducer.
Even the swing set material OEM brace has the proper angles on the
ends to conform to the chassis attachment points.
The A-Arm brace I made is constructed from an old S197 PanHard bar with
1/2" thick steel plates tack welded into the ends while mounted in position
on the vehicle. This set the proper angles requires for proper fit.
Then it was removed and fully welded and painted.
Even the bolts on the slotted attachment point side are spaced so
as to not allow any adjustment as it was built for my vehicle only.
If you are going to do it, and then show others, at least do it right...
And still doing its job 5 years later at zero cost to me.
Of course, I must mention that I have a full machine shop at my disposal.
For a shadetree brace, I guess his is fine and dandy.
Some demand perfection of their mods.
Other just cobble it up.
