New from Steeda - Front LCAs for 11-13
Check out our new front LCAs for the 11-13!
Steeda Street/Race Front Lower Control Arms w/ Ball Joints - 11-13
These specially modified factory O.E. arms are upgraded with high durometer urethane bushings for greatly reduced deflection and longer X11 ball joints for improved front suspension geometry.
Reduced bushing deflection will noticeably increase steering response and maintain proper alignment geometry during hard cornering. Our X11 ball joints will improve front geometry for increased cornering grip, reduced understeer, and reduced body roll.
Most importantly, these arms wont fold up and break under high stress conditions like aftermarket tubular designs. You get all the strength and durability that only the factory control arm assembly can provide!
Note: Due to the relocation from the longer ball joint, 18 inch or larger wheels are required for clearance.
Product Benefits
Product Benefits
- Will not fold up and break like aftermarket tubular designs
- Increased cornering grip - reduced understeer
- Maintains proper alignment geometry under hard braking
- Reduced body roll
[QUOTE=SteedaBrandon;8094591]Check out our new front LCAs for the 11-13!
[/QUOyou guys dont make any for the 05-09 mustangs? itd be nice if you did with the upgraded ball joint
09-24-2015 09:18 PM
