Just lowered my 08. What are my target alignment specs?
I installed Eibach Pro springs and camber adjustment bolts this Monday on my 08 CS. First, how long should I wait for these to settle? My camber is pretty negative at the moment so I'll take it easy until then. Secondly, what are the recommended specs so I can make the alignment guy's job that much easier?
I didn't pick one up at the time though I will once the aluminum adj. panhard is back in stock at AM. I can't visually notice the axle kicked out to the left but I'm sure the alignment machine will pick it up. I'm guessing I just need to get the front camber adjusted until I can get the panhard then have the back aligned?
Well that was a bust. Went to a tire chain in town and they refused to put it on their alignment machine without the adj. panhard bar installed. Is he correct or did he just not want to mess with it?
He wanted to do a good job for you but you did not have the
suspension items needed for him to properly complete the job.
He could have just did a toe adjustment (camber is non-adjustable OEM)
and sent you on your way charging you for a full alignment job.
Get the adj PH bar, adj UCA (for proper pinion angle) and a bump steer kit
and go back to him. Then he can properly attack the job.
Whats the full drop in inches front/back with the Eibach Pros?
Did you get aftermarket struts/shocks as well?
