View Poll Results: You have one mod to fix "wheel hop" what do you take?
Lower Control Arms
85.71%
Lowering Springs
14.29%
Voters: 7. You may not vote on this poll
lowering springs or LCA's?
I haven't used a variety of control arms to make a specific recommendation, but I think you'll find the right ones in your price range. I know Sam Strano has the whole line of UMI control arms that fall in that price range and he hasn't steered anyone wrong here yet. I went with the J&M Extreme arms because they fit my needs of articulation and price, combined with a daily driver. I haven't had a chance to drive on them so I can't say how well they work yet.
The J&M extreme joint lca's are a good compromise between poly/poly and poly/rod end. I think I paid less than $200 for mine. A poly/poly arm is going to bind on the street and I don't recommend running one. You will either crack the bushings or the arm! I corner hard, I do not spare the tires at all.
I did break a CHE adjustable lca, but I believe my axle being off 1/2 inch on one side was partly to blame. Still, I don't like the way Che welds the threaded rod to the bushing housing. There are better designs for adjustable control arms. Non-adjustable lca's are lighter, cheaper and for the most part stronger.
I wouldn't even recommend relocation brackets unless you are going to lower the back more than 1 inch. They will improve traction, but on a stock height car it may give a harsher ride. My car is lowered 1.5 inches and my lower control arms are at a 1-2 degree downward angle from front to rear mounting points. You don't want to much angle to the control arms.
I'm still unsure why I need my passenger side control arm shorter than the drivers side. I'd like to blame the CHE relocation brackets, but it could just be my car.
So, I got another question...If I do just the lower control arms...what ones to get? I see them ranging in price from $100 to $500 I'm just daily driving and I will hit the drag strip on most weekends. will the cheap ones work just fine? or is there a justification to spending more? Thanks
^^those UPR arms are Made in America, they carry a Lifetime Guarantee, and mf.com members get a discount on them. Most importantly, they are durable and they work really well. (tubular chrome-moly and Energy Suspension bushings)
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
