whats the magic degree for caster/camber?
Old 03-17-2013, 01:44 AM
DTMR
DTMR's Avatar
Default whats the magic degree for caster/camber?
I remember reading theres a certain about of camber that is actually good for handling, what degree is it? Will it create excessive tire wear? Installing coil overs soon so I wanted to know what was best for the alignment
DTMR is offline
Old 03-17-2013, 10:21 AM
Norm Peterson
Norm Peterson's Avatar
There is no such thing as a magic one-size-fits-all camber setting. What you need depends on several things.
For starters, how hard do you normally take corners? The harder your average cornering becomes, the more negative you'll want to set your camber. The flip side is also true - the further negative you set camber, the harder your average cornering has to become. Unless you're mixing in something like an occasional autocross.
So the first thing you need to do is honestly estimate where on the spectrum between "I never take corners hard at all" and "I never met a corner that I didn't step up to the challenge of" that your normal cornering really fits. This isn't a some's good/more's better/too much is just right quiz; too much is too much.
For reference, the OE preferred setting is -0.75°, and the max negative end of the OE "acceptable range" is -1.5°. Somewhere in there ought to work as an initial setting, and without knowing anything else I'd suggest running no more than about the middle of that range.
If you're doing your own C/O installation, you should be able to do your own alignment, in which case I'd suggest making whatever initial setting a little conservative (IOW, not as far negative as you think you can use), driving it, and resetting from there. Don't forget to check and reset toe, since that varies as you adjust camber.
Norm
Norm Peterson is offline
Old 03-18-2013, 04:34 AM
audioAl
audioAl's Avatar
Mr. Peterson know his stuff, I really appreciate his involvement in this forum. I'm 50 plus
years and he teaches me something every time I get on this forum. By the way, that is
what forums like this are for.
audioAl is offline
Old 03-18-2013, 01:27 PM
DTMR
DTMR's Avatar
Norm
I plan on doing some autocross events, drag racing, and maybee some track time. I know the camber will not effect the drag racing aspect, but I also do some very twisty road runs with my friends and my car's handling has not been up to par. I know that too much camber will also effect braking and tire wear, so I think I will try a -1.0 (in the middle like you said) and see where it takes me.
DTMR is offline
Old 03-19-2013, 08:05 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
I'm around -1.75°. Steering is improved and tire wear is reasonable.
UPRSharad is offline
mtgldr
02-03-2024 09:00 PM
BOB ROME
07-26-2023 01:54 PM
Gene K
10-21-2015 11:37 PM
Explosive
10-02-2015 07:45 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: whats the magic degree for caster/camber?
