SP Performance Disc Brake Rotors
We've had some good luck with the SP Performance rotors, we will sell them on occasion.
If you get the Zinc coated version a pro would be the cut down on rust. Can't think of any cons.
If you have a GT with the Brembos, you should look at the DBA T3 4000 which we are practically giving away. They are more durable than the SP rotors because they are heat treated, they also will dissipate heat better due to their Kangaroo Paw venting.
http://bossmustangsonline.com/index.php?topic=6489.0
-Nick
-Nick
SP Performance rotors you can get with or without the zinc plating.
The DBA rotors are not zinc coated but what DBA does is put on an anti corrosion coating over the hat and inside the veins of the rotor, helps to eliminate the build up of rust.
-Nick
musnicki
09-23-2015 07:11 AM
maestro1024
09-21-2015 02:40 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
