Widest tire for lowered mustang
I have a 2011 Mustang GT with SVE 19"x9.5" Drift wheels. I have lowered the car with Eibach springs, and I use the car for canyon carving.
Offset +35mm
Backspacing 6.63"
I'd like to put some 285 Nitto tires on the car...but before I buy I want to know if they will fit. Anyone running tires like this?
Offset +35mm
Backspacing 6.63"
I run 315's on the back of mine but they stick out the fenders a bit, and do rub. I'd say 20x11 with a 305 is the largest fitment you can run on the back of the car.
With a 9.5 though, I'd say 285's are perfect, and 295's are a little bulged, but they do work.
I'm running a 285/40/18 on 18x10 SVE drift wheels
So what tire r u gonna want to run on the rear? 285/35/19? That will be less than the stock 27.1 inch diameter so u will need to correct for that. That should be no problem on the front since ur offset is a 35 instead of 43 for the 18s
I am assuming you are talking about a speedo issue with the diameter of the tires...will a tuner fix that issue?
if you go with a shorter tire, you will have more wheel gap. I prefer a 28 inch tire for looks.
shorter tire will be lighter and lower your gearing and probably increase your performance slightly overall though.
