Fitting some un-orthodox tires
Hey guys. Last weekend I did an HPDE at MSR Cresson, and I made a contact that can get me some ALMS team Pirelli P-Zero LM slick scrubs for very cheap. This guy runs them on his Vette, and is able to get 3 or 4 track days out of them, and he is a much better/aggresive driver than I am. The tires available to me are sized 305/660 18 and 305/675 18 (sizing chart: http://www.pirelli.com/tyre/ww/en/mo...eet/slick.html). Now from what I can tell I would need a 18x9.5" rim I believe. So what I need to know is either what kind of rim offset or what kind of spacer I would need to run in order to fit these tires. I am still in the middle of researching this, so if I find the answer myself I will update this, but in the mean time I would like to get others' opinions. I would also like suggestions on brands of rims that will fit these. Thanks.
I found out that the 07 GT500 rims have a 45 mm offset, which is one of the offsets that Sam sells for his Enkei's, but I don't see any indication that people have run 305's on them, which makes it seem like this isn't feasible. My contact did say that he had seen a guy put these tires on "GT500 knock offs" before though.
I would recommend you getting a 10" rim for the tires to properly fit and the 10" rim will still be tight. I'm running 18x10 Forgestar F14's with a 42 offset and they clear just fine with a 295 on all fours. You might need a spacer to clear with 305's. I recommend the spacers from maximum motorsports because they are an exact fit for our mustangs and don't cause excess wheel vibrations.
Originally Posted by darksky1984
(Post 8338484)
Ok so after some more research I've discovered the Roush Trak Pak wheels were 18x10 with a 45mm offset. These SVE Drift wheels:
http://www.latemodelrestoration.com/...VE-Drift-18X10 are 18x10 with a 43mm offset. So that would put the SVE's 2 mm in-board compared to the Roush ones. I am trying to find out what tire sizes those cars came with to start. EDIT: Those 10" rims only had 275's on them, so doesn't tell me much. |
Enkei PF01 wheels at 18 x 10.5 (Sam sells them along with a pair of 5mm spacers for the front that may or may not be necessary depending on actual tire section and tread widths as installed)
Forgestar 18 x 11 (Vorshlag . . . call them to discuss . . . IIRC the fronts and rears are not the same offset, and you'll need to run a bit more negative camber) Norm |
1 Attachment(s)
43mm will sit 2 mm more outboard than the Roush wheels
I have 285/40/18 on the sve drift wheels all around with no rubbing and they are nearly flush with the fenders, maybe a hair tucked in. |
Originally Posted by Norm Peterson
(Post 8338594)
Originally Posted by UrS4
(Post 8338606)
Yes 18x10
