Bear 14 inch rotor upgrade
Old 03-14-2014, 11:43 PM
slickman
slickman's Avatar
Originally Posted by UrS4
So I take it you've called Baer to make sure your 17" skinnies will fit? As their website say it may clear OEM wheels but usually requires larger wheels. Definately a vague statement as 17 and 18" wheels are OEM.
I think this upgrade is overkill if you are just concerned about slowing down from a few triple digit runs at the strip. If you take it on the road courses then its fine.
I like a little overkill, 600 hp is overkill for the street but I love it ;-) Yes, this setup clears with no problem my 20 in wheels (I run on the street) and 17 inch wheels (that I run on the track) both clear with no problems at all. They even have a template you can download to test the fit (which I did). Everything fits like a glove, unless you go with after market calipers then 18 in would be the min size. With the OEM caliper, it works out great for me. Oh and the kit does come with a new caliper bracket, thats one thing you can't use with this upgrade kit.
Here they are all installed using the OEM caliper and SBC red pads, Those rims are 20's
slickman is offline
Old 03-14-2014, 11:52 PM
UrS4
UrS4's Avatar
Looks great!
UrS4 is offline
Old 03-15-2014, 01:05 AM
Rudolph Hucker
Rudolph Hucker's Avatar
looks good
brembo calipers next i rekon?
Rudolph Hucker is offline
Old 03-15-2014, 06:18 AM
jpplaw
jpplaw's Avatar
17 x 4.5 Racestars fit over GT500 4-piston Brembos & 14" Baer Rotors, no problem
jpplaw is offline
Old 03-15-2014, 07:45 AM
Scott2
Scott2's Avatar
Baer 6P 14" brakes with 17" Racestars fit no problem as well.
Scott2 is offline
Old 03-15-2014, 10:22 AM
slickman
slickman's Avatar
The Racestars are what I have for the track, this is good to know. I was wondering about the Baer 6P fitting.. Your setup is exactly the same as I have, 17x4's up front and 15x10's in the rear..
What size tire are you running on the rear?
slickman is offline
Old 03-16-2014, 08:53 AM
Scott2
Scott2's Avatar
Mickey Thompson ET Street Radials - 325/50R15.
Scott2 is offline
Old 03-16-2014, 09:02 AM
slickman
slickman's Avatar
Nice to know to know those fit. Nice setup you have there!
slickman is offline
Old 03-17-2014, 05:41 AM
Scott2
Scott2's Avatar
Takes some work to get them to fit - of course trim the sway bar bracket (for the 15" rims) and then relocate the jounce bumper to under the frame rail and cut off the jounce bumper "stop bracket" extending out from the frame rail. Let me know if you want me to post pictures of what needs to be done?
Scott2 is offline
Old 03-17-2014, 06:21 AM
slickman
slickman's Avatar
Yeah, the sway bar I already took care of, installed a whiteline and cut the original sway bar brackets off. The bounce bumper I already cut the tip off. I would like to see some pics of what you did to the bracket? It looked like 12 inch wide slicks should not be a problem with these rims without cutting that bracket.
Right now I'm casually looking around for some 4 piston calipers new or used that will work wit my setup.
slickman is offline
Quick Reply: Bear 14 inch rotor upgrade
