Mustang sitting uneven?
Old 04-21-2014, 09:32 AM
l00kitzzlilcj
l00kitzzlilcj's Avatar
Originally Posted by Norm Peterson
Did you loosen at least the LCA control arm bolts and re-tighten them at the new (lower) ride height? Check your LCA bushings (and the UCA bushings to the extent possible) for possible tearing.
Norm
I didn't do this. Should I though? I'll definitely take a look at those bushings when I get the chance at least
l00kitzzlilcj is offline
Old 04-21-2014, 09:42 AM
Norm Peterson
Norm Peterson's Avatar
For any change in ride height where you retain the OE rubber bushings in the control arms, you should do that. If you had kept the OE PHB, you would have been best off to do the same thing for it as well. Basically, you don't want there to be any preload on these bushings because suspension bump travel from there can overstress the rubber bushings and tear them.
Norm
Norm Peterson is offline
cyclop5
10-03-2015 09:21 PM
Stangbass
08-22-2015 08:33 AM
cvarner131
08-17-2015 07:38 AM
daytooday
08-11-2015 09:22 AM
tmdm
08-07-2015 10:24 PM
Quick Reply: Mustang sitting uneven?
