Need Part # for GT SB endlinks & Diff CA Bushing
Old 06-07-2017, 12:16 PM
Glenn Ford
Glenn Ford's Avatar
Default Need Part # for GT SB endlinks & Diff CA Bushing
I have a 2012 GT and I am looking for a possible Moog part # for the SB endlinks. I tried Moog part #K700507 and I could not get them to go on the bar.
Also does anyone have a part # for the rear differential control arm bushing (the rear bushing)?
Thanks for any help.
Glenn
Glenn Ford is offline
Old 06-08-2017, 06:41 AM
Scott2
Scott2's Avatar
Can't help you on the endlinks.
If you are talking about the differential bushing, here you go:
You also have an option for a BMR bushing. The BMR bushing uses the OEM metal sleeve. Part number EN001
Scott2 is offline
Old 06-08-2017, 10:00 AM
flash_xx
flash_xx's Avatar
I used the Steeda Mustang Spherical Bearing (05-14) https://www.steeda.com/steeda-mustan...-555-4104.html to help the rear end rotate a bit. The arm has a solid poly bushing on the chassis side for NVH.
flash_xx is offline
Old 06-08-2017, 11:46 AM
Glenn Ford
Glenn Ford's Avatar
Thank you for your help on the diff bushing.
Still can not locate endlinks for my 2012 GT. Has anyone replace them on their GT? Any help appreciated on the endlinks. Would the optional 19" tires make a difference?
Old 06-08-2017, 01:36 PM
Derf00
Gentleman's Relish
Derf00's Avatar
K700507 is for a 22mm bar.
K750137 is for 17 mm bar
http://www.rockauto.com/en/catalog/f...+bar+link,7580
Derf00 is offline
Old 06-08-2017, 01:43 PM
Glenn Ford
Glenn Ford's Avatar
Bought K700507 and it was too small. Called Moog and they said that endlink is not for the GT. They do not carry an endlink for the GT. Many websites have it listed incorrectly. I believe my SB is 24mm, but can not find a 24mm endlink anywhere except Ford.
Old 06-08-2017, 01:49 PM
Derf00
Gentleman's Relish
Derf00's Avatar
24 mm? Maybe BOSS size? Rock has the ones for a BOSS too.
Derf00 is offline
Old 06-09-2017, 08:34 PM
Glenn Ford
Glenn Ford's Avatar
I guess I have a somewhat unusual 2012 GT. I miced my SB and it is 24mm not 22mm. I believe my 19" tires pushed the SB from to 22mm to 24mm. I wonder how many GT have the optional 19" tires. I would like to hear from any other owners. It would be great if 19" tire owners would also mic their 19" tire SBs to verify they are 24mms. Their are NO aftermarket 24mm SB endlinks. I can state this with a high degree of confidence after all my research. If someone has found 24mm endlinks please post the part # and link.
BTW - Boss 302 SBs are 22mm.
Old 06-10-2017, 09:38 PM
flash_xx
flash_xx's Avatar
I have MOOG endlinks on mine. I got them for the stock bar and reused them when I got the FRPP sway bar kit. Moog K80899 Stabilizer Bar Link Kit. Got them off Amazon.
Amazon Amazon
Duh, I just realized you're probably looking for the rear ones. There I can't help because my kit came with really nice billet aluminum endlinks. Try LMR.COM That's where I get almost all my stuff.
flash_xx is offline
