aftermarket sway bar with sway bar relocation brackets
Looking to replace my sway bars on my 2013 GT, but I have sway bar relocation brackets (for 15" rims/slicks)- anyone know of any aftermarket brands that will fit with relocation brackets?
keving, I hope this will answer your question.
The current location of the factory sway bar mounts won't clear 15" drag wheels. The past solution to this problem was to cut the brackets and removing the sway bar entirely. Thanks to BMR, there's now a better option. The BMR Sway Bar Relocation Kit provides a new mounting point higher up on the brackets. Installing these stainless-steel brackets allows you to keep your sway bar while running 15-inch drag wheels. If I remember right, the part number is: SRK001
sd07gt
03-10-2007 08:57 PM
