Mustang 2015-2018 GT (S550) Brakes on S197
At Tasca Ford where i bought the parts, they kept telling me that the part they send was the correct one P/N FR3Z-2068-C. That is the hardware kit for the Brembo caliper not the S550.So i send it back, went to napa store and got the correct kit P/N UP 84274A. Google both parts number and you will see the difference. Yes i got the Centric rotors, i put the left side on this afternoon and it fits perfectly. I used 1/4" spacers because the wheel was to close to the caliper and i didn't like it so close. I have 18" X 9" Saleen wheels.I removed everything so i can paint the calipers tomorrow, i will take pictures when i finish.
There seems to be a misunderstanding,a washer must be used to "center" the calipers. The "spacer" is used in front of the rotor to push the wheel out to clear the calipers, depending on your wheel, you may need one or not. I could have used my wheel without the spacer (1/4") but did not like it so close to the caliper probably 1/16" between the wheel spokes and the caliper. Hopefully this clears the issue.
If 1/16" at the caliper radius isn't enough to avoid a rub, you may need to look for bigger problems than just the clearance being a bit tight. A 1/8" spacer would have been more than plenty, while being better than 1/4" in terms of lug nut thread engagement, which should be at least one full stud diameter (1/2", or 10 full turns of the nut).
As a (retired) structural guy I'm a fan of using the thinnest spacer you can get away with. Even made a couple out of 0.025" sheet aluminum for my '08 on account of 11" wide front wheels.
Norm
That's the information I was looking for.
Norm
Norm
