Mustang 2015-2018 GT (S550) Brakes on S197 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 2005-2014 Mustangs > S197 Handling Section
Reload this Page >
Old 09-09-2018, 02:13 AM
08'MustangDude
Default Mustang 2015-2018 GT (S550) Brakes on S197
Not sure if this is out there, but I found it... This is not a really how to guide. This is just a list of
all the parts needed, and suggestions.
The front calipers on the S550 Mustang GT are 4 piston, and are much cheaper compared to
4 piston Brembo calipers.
For starters, you need to make sure your existing rims will clear the Mustang
2015 2018 GT calipers, because these calipers are big, even bigger than 4
piston Brembo calipers. Most people can use 3-5mm wheel spacers to clear the
calipers.
19"x8.5" Rims Clear.
BASIC S550 Wheel Specs:
17 x 7.5 with 235/55/17 ET37.5 (STOCK) - V6 & I4
18 x 8.0 with 235/50/18 ET40 (STOCK) - GT
19 x 9.0 with 265/35/19 ET42.5 (PERFORMANCE PACK) - V6
19 x 9.0 with 255/40/19 ET42.5 (PERFORMANCE PACK) - GT
19 x 9.5 with 275/40/19 ET42.5 (PERFORMANCE PACK) - GT
The front calipers on S550 Mustang GT are 4 piston, and cheaper when compared to the
4 piston Brembo calipers. Rather than spend $600+ on the Brembo, you should be able
get '15-'18 S550 Calipers on eBay, for half the cost, and they may come loaded (with pads).
Parts Required:
First thing you'll need is front calipers off a '15'18 Mustang GT (S550). You can buy them
on eBay for anything between $225-$275. Make sure to buy calipers only, do not buy sets
with rotors. Some may come with pads, some may not, but you will need the pads for
those calipers as well.
Ford part# for Calipers: FR3Z-2B120-H (LH) FR3Z-2B121-H (RH) / eBay, Tasca.
If you do not get loaded calipers, you will need pads. When you order pads, they are
for S550 cars WITHOUT performance package, as they have the Brembo calipers.
Pads:
Ford: GR3Z-2001-B
The next thing needed are 14" rotors for your '05'14. You can use plain old Centric blank
rotors, but you can buy drilled and slotted as well as long as they are 14". You only need
two of course, front left and right.
Blank:
Centric Part# 120.61089 with e-coating, front left and right.
Drilled and slotted:
StopTech 127.61089L Sport Drilled/Slotted Brake Rotor (Front Left)
StopTech 127.61089R Sport Drilled/Slotted Brake Rotor (Front Right)
Slotted Only:
StopTech 126.61089SL StopTech Sport Rotor Front Left
StopTech 126.61089R StopTech Sport Rotor Front Right
Next, it's suggested that you use Stainless Steel brake lines. You CANNOT use the brake
lines from S550 calipers on an S197.
SS Brake Lines:
2005-2014 Ford Mustang Stainless Steel Brake Hose Kit with ABS Front 22530F
Russell 693380 Brake Hose Kit for Mustang 05
Stop Tech 950.61003 Stainless Steel Brake Lines
The stop tech lines are poor quality, and you need to be careful installing them. The quality of banjo
bolts with this set is not good, and may break before it can be fully tightened to 26 ft-lb.
You will need a TR15 screwdriver to screw the brake line to the support on the cars body:
On the driver side, the bracket for the brake line will be in the way of the plastic cover, cut the plastic cover for it:
With the S550 Caliper on a S197, the rotor is not centered. To center the rotor, use a washer on each of the bolts used to
mount the caliper, four washers, Dorman Part # 766-014N. The washer need to be between the bolt and the caliper.
caliper < washer < spindle < bolt
The only other thing you may need is a piston compression tool.
This is what it would look like when completed:
There you have it, S550 Front Calipers on your S197.
08'MustangDude is online now
Old 09-09-2018, 02:19 AM
08'MustangDude
For some reason, three pictures are not working, and I can see them when I edit the post,
but they do not come up when saving.
Old 09-09-2018, 02:29 AM
AK_Kayaker
AK_Kayaker's Avatar
This is not a really how to guide. This is just a list of all the parts needed, and
suggestions.
calipers.
get '15-'18 S550 Calipers on eBay, for half the cost, and they may come loaded.
Parts Required:
Blank:
Slotted Only:
SS Brake Lines:
What's weird is in the post I only see one pic, when I quoted it, it showed four pics, very strange..
Then it went back to only one are I clicked post.
AK_Kayaker is offline
Old 09-09-2018, 08:13 AM
Moderator
JimC's Avatar
Very odd because I hit the edit as a mod and all the pictures show up, so I tried to save it but only one picture in the post again.
I think we need to blame gravydog for this, she has problems with pictures.
JimC is online now
Old 09-12-2018, 02:28 PM
Derf00
Nice write up 08Mustang.
BTW Gravydog's bewb picture broke the forum
Derf00 is offline
Old 09-21-2018, 04:50 AM
08'MustangDude
I uploaded the images to my Servimg account, they are working now.
Old 12-21-2018, 09:14 PM
CableDawg
Default Illegal mod in stock classes?
Is this a mod that would bar a 2011-2014 Stang (302/M6) from competing in stockish classes in autox?
CableDawg is offline
Old 12-22-2018, 09:27 AM
Norm Peterson
Norm Peterson's Avatar
Probably not stock/street category legal, at least with most organizations.
But for autocross all you really need are better pads.
Norm
Norm Peterson is offline
Old 01-12-2019, 04:55 PM
Rleary
whats the smallest size wheel that will fit those calipers?
Rleary is offline
Old 02-09-2019, 08:28 PM
08'MustangDude
17" Rims, but the offset is ET37.5
Quick Reply: Mustang 2015-2018 GT (S550) Brakes on S197
Featured Sponsors
