Uneven Tire Wear on all 4 tires
Well that's the thing, since I haven't gotten an alignment yet, I really have no clue what the settings are. I just tried my absolute best to get the center threaded piece (that feeds through the strut) to be in the center of the hole of the CC plate. I'm not 100% sure if that makes sense, but I did my best.
It is possible for the rear axle cambers (and toes) to not be zero, though it's unlikely that they'll be very far from zero (half a degree in an axle not intentionally cambered would be a huge amount). You can make those measurements yourself as well. FWIW, rear cambers as high as -0.5° shouldn't wear tires all that badly unless the driving includes frequent wheel-spin and little or no hard cornering.
My opinion is that optimum camber depends very much on an individual's driving habits. Mfr preferred settings are good for some overall average kind of driving for the classic 'average driver', where performance is not a priority. Simplified, mainly highway and straight line driving can benefit from setting cambers a little less negative than factory preferred, serious corner-carving needs cambers to be considerably more negative (-2.0° in the above picture). Somewhere in that range is every individual's optimum setting. Factory camber for at least the early-years of S197 calls for -0.75° (preferred), with 0° being the minimum negative and -1.5° the maximum negative.
Norm
smitty2919
13
06-29-2010 02:23 PM
