2010 stock shelby tires
my 2010 shelby has the steering wheel shake. the car has 6k miles. have had them balanced twice. it still shakes. tires were great when new, no shake. what gives guys?
mine does the same thing arounD 80+ had the wheels balanced twice
your TPMS might have come loose and is spinning around inside the rim...
Or the hamster died. :D
Originally Posted by Orion_240
(Post 6775198)
Originally Posted by hockeyman8282
(Post 6775359)
do i have tpms in my 06?
Most likely not. This was required on 07 (I believe) and up. |
rotating is the key to recognizing a specific wheel issue. It is not likely that all wheels went out of balance at the same time. A tire could have a broken belt, but those usually have slightly different symptoms. Does this vibration only happen at higher speeds? If you rotate the tires does it change the vibration? Does the vibration change depending on how long you drive the vehicle? All of these give cues to the service writers so they can help technicians with a proper diagnostic.
