Magnetic Ride Suspension.. what do you think?
Yeah I don't see the magnetic selective shocks as being the stock equipment, but I think it would be a good option. I think it would improve ride quality most of all by being able to keep the dampers soft until it had to dampen out large perturbations from road conditions. The one issue I see is that ford would have to add a flexray bus in order to get the dampers to process data quick enough to be useful.
But for the vast majority of people, the magnetic suspension is a major improvement.
As far as it being option-only? It always starts out that way.
Norm
Yeah I know what you mean. Rear can be a bit harsh over dips and bumps. Part of it I would say is due to the Live axle. It makes bumps harsher than an IRS would.
Swapping in Konis would be a world of difference for our cars. However, since we are talking about the MR, there is no better alternative unless someone is going to race spec shocks/springs. I have never heard of anyone with a Z or V swapping out their MR unless they were racing it.
I have never even heard of anyone bad mouthing the MR. All the journos applaud it.
the 458 italia, 599GTB, R8 feature the MR. No one changes those out.
And that pretty much by definition people who belong to sites such as this one and get involved in the technical sections are not typical car owners.
I'm not trying to say that the MR's aren't any good, just that somebody else's definition of "good" is not guaranteed to match up with my definition, or yours, or anybody else's given that we're the ones who would seriously consider swapping out the OE shocks and struts before the first oil change came due.
I'm not going to suggest that any overt editorial pressures might exist, but . . . magazines do not survive on subscription and OTC sales alone.
[/D.A.]
Who knows, maybe some outfit will come up with something that I'd be completely happy with. I'd still want to know in a lot more detail what it did and how it did it - specifically because of the added complexity. Not in less detail with the implication being that I should trust it and its tuning implicitly.
Norm
One addition that I would like to see that is probably more beneficial than MR shocks is active anti-roll bars. BMW has been using these for a few years now, and they are absolutely fantastic. It uses the power steering pump to pressurize the system, and then a valvebody to pass fluid in different directions across a viscous coupling in the middle of the sway bar. This coupling can apply a ton of torque in either direction to the front and rear sway bars. The benefit here is that when driving in a straight line, no fluid is passed through the bar, and so it is the equivalent of running no sway bars (aka soft, cushy ride). As soon as you go into a hard turn, it applies torque to the sway bar to keep the body from rolling. The net effect is zero body roll even during the most aggressive cornering (even on their SUVs).
Predictability = quick/fast because you know what's happening without having to wait until the transient portion of the maneuver is over to find out if it really took a set when and where you were hoping it would.
Linearity = predictability, and by definition, active suspension components are going to have nonlinear behavior even in the ranges where linearity is important. Dunno, maybe this doesn't matter at all to the driver who's only pointing the car accurately enough to stay on the black stuff.
Zero roll is not unanimously considered a good thing, as the absence of roll can convey the impression that the tire behavior is remaining linear when it clearly might not be. I firmly believe that a car should not be telling that sort of lies to its driver.
Active sta-bars and MR technology would probably be a much better fit for a new generation T-bird, since that nameplate's mission has always been to be at least a couple of steps more luxurious than the Mustang's.
Norm
