2007 GT 500 Supercharge Pulley
2007 GT 500 Supercharge Pulley - Dyno Result!!
i am new on forum and don't want to make any mistake modify my car. I am new owner of 2007 GT 500 with already K&N Air Intake with Axle back exhaust.
i would like to add following:
- Metco Suerpcharger Pulley 2.60 in. (from American Muscle)
- Metco Pulley Kit - double bearing
- NGK V-Power Heat Range 6
- KBB 65mm BT
My question, would be:
- can factory clutch can take the extra power or i need to upgrade it?
- is it anything i should be concern? love my car and don't won't to jeorpardy motors/supercharge
Love to see feedback before making those upgrade
thanks and have a great day,
Claude
- KBB 65mm BT
Claude
I am pretty sure you're fine with the clutch and pressure plate...
The Tremec TR6060 is rated at 600 ft-lbs. There is a Magnum version, rated at 700 ft-lbs.
http://www.tremec.com/anexos/File/TR-6060-010408.pdf
You have a GT500, you're at 480 ft-lbs torque. You also have to take into consideration
what the internals can handle, which is 600 ft-lbs for your TR6060. I don't think you're going
upwards of +120 ft-lbs of torque with a pulley change, with a boost Increase of 3-5 PSI
with that pulley. Stage 2 pack, you're looking at, somewhere around 548 horsepower and 545 ft-lbs
torque, still not over the rating, but pushing it.
Last weekend custom tune (SVT X4) and dyno by http://www.performance-dyno.com/index.html. see result, i am very impressed for so little change.
stags
06-05-2011 11:30 AM
ibayter
09-30-2008 06:32 AM
